Bonjour à tous.
Voilà j'ai un petit problème.
Je n'y connais pas grand chose en asp et j'essaie de me dépatouiller comme je peux.
Je souhaiterais créer une page qui duplique les contacts d'un fournisseur.
J'ai essayer un code récupérer sur un site ASP mais j'ai beaucoup de mal à l'ajuster à mon besoin. Voici ce que ca donne :
<%@LANGUAGE="VBSCRIPT"%>
Set MM_Cmd = Server.CreateObject("ADODB.Command")
MM_Cmd.ActiveConnection = "dsn=intranet_lisadis;"
myarray=split(request("fonction_contact_frs"),",")
myarray2=split(request("nom_contact_frs"),",")
myarray3=split(request("mail_contact_frs"),",")
myarray4=split(request("tel_contact_frs"),",")
myarray5=split(request("port_contact_frs"),",")
myarray6=split(request("n_frs"),",")
myarray7=split(request("ordre_apparition"),",")
for i=0 to ubound(myarray)
MM_Cmd.CommandText = "INSERT INTO Table_contacts_frs (fonction_contact_frs,nom_contact_frs,mail_contact_frs,tel_contact_frs,port_contact_frs,n_frs,ordre_apparition) VALUES (" & myarray(i) & "," & myarray2(i) & "," & myarray3(i) & "," & myarray4(i) & "," & myarray5(i) & "," & myarray6(i) & "," & myarray7(i) & ")"
MM_Cmd.Execute
next
Dim contacts__MMColParam
contacts__MMColParam = "0"
if(Request.QueryString("n_fiche_frs") <> "") then contacts__MMColParam = Request.QueryString("n_fiche_frs")
set contacts = Server.CreateObject("ADODB.Recordset")
contacts.ActiveConnection = "dsn=intranet_lisadis;"contacts.Source
"SELECT * FROM Table_contacts_frs WHERE n_frs " + Replace(contacts__MMColParam, "'", "''") + ""
contacts.CursorType = 0
contacts.CursorLocation = 2
contacts.LockType = 3
contacts.Open
contacts_numRows = 0
set dernier_n_frs = Server.CreateObject("ADODB.Recordset")
dernier_n_frs.ActiveConnection = "dsn=intranet_lisadis;"
dernier_n_frs.Source = "SELECT * FROM Requete_duplication_contacts_frs"
dernier_n_frs.CursorType = 0
dernier_n_frs.CursorLocation = 2
dernier_n_frs.LockType = 3
dernier_n_frs.Open
dernier_n_frs_numRows = 0
Dim Repeat1__numRows
Repeat1__numRows = -1
Dim Repeat1__index
Repeat1__index = 0
contacts_numRows = contacts_numRows + Repeat1__numRows
<html>
<head>
<title>Duplication_contact_frs</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<form method="post" action="">
While ((Repeat1__numRows <> 0) AND (NOT contacts.EOF))
Repeat1__index=Repeat1__index+1
Repeat1__numRows=Repeat1__numRows-1
contacts.MoveNext()
Wend
</form>
</html>
Après validation de ce formulaire le résultat donne ca :
Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
[Microsoft][Pilote ODBC Microsoft Access] Erreur de syntaxe (opérateur absent) dans l'expression 'Assistante Commerciale'.
/lisadis/fiche_frs_duplication_2.asp, line 18
Est-ce que quelqu'un pourrais m'aider ???
Merci d'avance.
Oketto.
Afficher la suite
