Soyez le premier à donner votre avis sur cette source.
Vue 6 882 fois - Téléchargée 660 fois
<?php /*Auteur : arboretom*/ $filename = "class/Config.class.php"; if (file_exists($filename)) { include($filename); class ClassSql extends Config{ function ClassSql() {$connection = @mysql_connect($this->host, $this->user, $this->pass) or die("Impossible de se connecter : " . mysql_error()."<br>"); return$connection; } //->Liste toute les base du serveur function list_base(){ $db_list = mysql_list_dbs($this->ClassSql()); $base=$_GET["base"]; echo "<center><form name='form1' method='get' action='".$_SERVER['PHP_SELF']."'> <select name='base' onchange='form1.submit();'>"; echo " <option >Choix de la base</option>"; while ($row = mysql_fetch_object($db_list)) { echo " <option value='".$row->Database."'>".$row->Database."</option>"; }echo "</select><br>Nom de la base :<b> $base</b> </form></center>"; $this->list_table($base); } //->liste les table function list_table($baseSelect){ $tableNames = mysql_list_tables($baseSelect, $this->ClassSql()); mysql_select_db($baseSelect); $base=$_GET["base"]; $table=$_GET["table"]; if($baseSelect !=""){ echo '<center><input type="button" value="Actualiser" OnClick="history.go(0)"></form></center>'; echo "<table align='center' border='1' cellspacing='0' cellpadding='15'>"; echo "<tr>"; echo "<th>table</th><th>nb champ</th><th>Nb enreg</th>"; echo"<th>Source</th>"; echo"</tr>"; while ($row = mysql_fetch_row($tableNames)) { $req="SELECT * FROM ".$row[0].""; $result = mysql_query($req); $fields = mysql_num_fields($result); $num_rows = mysql_num_rows($result); echo "<tr ><td >"; echo" Créer la source <a href='".$_SERVER['PHP_SELF']."?base=$baseSelect&table=".$row[0]."'>".$row[0]."</a></td><td>".$fields."</td><td>$num_rows"; echo "</td><td>"; $nom_dossier=$row[0]; $exist_doss=is_dir($nom_dossier); if(!$exist_doss){echo"pas encore Creer";} else{ echo "<a href='".$row[0]."/".$row[0]."_View_all.php' target='_blank'>".$row[0]."_View_all.php</a> | "; echo "<a href='highlight.php?title=".$row[0]."/".$row[0]."_View_all.php' target='_blank'>source</a><br>"; echo "<a href='".$row[0]."/Form_".$row[0].".php' target='_blank'>Form_".$row[0].".php</a>|"; echo "<a href='highlight.php?title=".$row[0]."/Form_".$row[0].".php' target='_blank'>source</a><br>"; echo "<a href='".$row[0]."/".$row[0]."_Links.php' target='_blank'>".$row[0]."_links.php</a>|"; echo "<a href='highlight.php?title=".$row[0]."/".$row[0]."_Links.php' target='_blank'>source</a><br>"; echo "<a href='".$row[0]."/Form_".$row[0]."_update.php' target='_blank'>".$row[0]."_update.php</a>|"; echo "<a href='highlight.php?title=".$row[0]."/Form_".$row[0]."_update.php' target='_blank'>source</a><br>"; } echo"</td></tr>"; } } echo "</table>"; $base=$_GET["base"]; $table=$_GET["table"]; $this->list_row($base,$table); } //->liste les enregistrement et creer les fichier function list_row($base,$table){ mysql_select_db($base); if($table !=""){ $req="SELECT * FROM $table"; $result = mysql_query($req); $fields = mysql_num_fields($result); $numa = mysql_num_rows ($result); $retourligne="\n"; $var="$"; $br=".\"<br>\""; for ($j=0; $j < $fields; $j++) { $name = mysql_field_name($result, $j); $namefield.=$var.$name."=".$var."dbview->field('".$name."');".$retourligne; $echofield.="echo".$var.$name.$br.";".$retourligne; } $brace_debut="<?php\n"; $brace_fin="\n?>"; $conectfile='include("../class/Config.class.php");'.$retourligne;; $conectfile.='include("../class/extend.sql.class.php");'.$retourligne;; $boucledebut="while(".$var."dbview->next_record()){".$retourligne; $bouclefin="}".$retourligne; $confbase=$var."base=\"$base\";".$retourligne; $conftable=$var."table=\"$table\";".$retourligne; $declaration=$var."dbview = new sql(".$var."base);".$retourligne; $query=$var."dbview->query(\"select * from ".$var."table\");".$retourligne; $textecount=".\" enregistrements\""; $count=$var."count=".$var."dbview->countfield();".$retourligne."echo".$var."count".$textecount.$br.";".$retourligne; $args=$brace_debut; $args.=$conectfile; $args.=$confbase; $args.=$conftable; $args.=$declaration; $args.=$query; $args.=$count; $args.=$boucledebut; $args.=$namefield; $args.=$echofield; $args.=$bouclefin; $args.=$brace_fin; mysql_select_db($base); $req="SELECT * FROM $table"; $result = mysql_query($req); $fields = mysql_num_fields($result); $num_rows = mysql_num_rows($result); for ($i=0; $i < $fields; $i++) { $type = mysql_field_type($result, $i); $name = mysql_field_name($result, $i); $len = mysql_field_len($result, $i); $flags = mysql_field_flags($result, $i); if($len >255 ){ $input.=" echo \"$name<textarea rows='5' cols='40' wrap='on' name='$name'>"; $input.="</textarea><br>\";\n"; } elseif($len <50 ){$input.="echo\"$name : <input type='text' name='$name' value=''size='$len'><br>\";\n";} else{$input.="echo\"$name : <input type='text' name='$name' value=''size='50'><br>\";\n";} } $this->creer_dossier($table); $this->CreateFile($table."/".$table."_View_all.php" , $args); $formaction='$db = new sql($base);'.$retourligne.'$action=$_POST["action"]; if($action=="insert"){echo "$action"; $db->insert("$table VALUES('; for ($i=0; $i < $fields; $i++) { $name = mysql_field_name($result, $i); $namechamp .="'$".$name."',"; } $name0 = mysql_field_name($result, 0); $name001 = mysql_field_name($result, 1); $name01 ="$". mysql_field_name($result, 0); for ($i=0; $i < $fields; $i++) { $name = mysql_field_name($result, $i); $namechamp_up .= "$name ='$".$name."',"; } $rest_up = substr($namechamp_up, 0, -1); $rest = substr($namechamp, 0, -1); $fininsert=")\");\n echo\"<A HREF='Javascript:history.go(-1)'>Retour</A>\"; \n exit; } elseif(".'$'."action==\"update\"){ $"."db->update(\"$"."table SET $rest_up WHERE $name0='$name01'\"); \n echo\"<A HREF='Javascript:history.go(-1)'>Retour</A>\"; \n exit; } elseif(".'$'."action=='delete'){}\n"; $file_php=$light_php.$conectfile.$rest.$fininsert; $nom_doss="Tool_sql/admin_".$table; $filesform=$table."/Form_".$table.".php"; $debut_form="$"."form_action=\"Form_".$table.".php\"; \n echo\"<form name='$table' method='post' action='$"."form_action'>\";\n"; $fin_form="echo\"<input type='hidden' name='action' value='insert'>\n<input type='submit' value='insert'>\n</form>\";"; $fin_form_update="echo\"<input type='hidden' name='action' value='update'>\n<input type='submit' value='insert'>\n</form>\";"; $argsform=$brace_debut; $argsform.=$conectfile; $argsform.=$confbase; $argsform.=$conftable; $argsform.=$declaration; $argsform.=$query; $argsform.=$count; $argsform.=$formaction.$rest.$fininsert; $argsform.=$debut_form.$input.$fin_form; $argsform.=$brace_fin; $this->CreateFile($table."/Form_".$table.".php" , $argsform); $argsLinks=$brace_debut; $argsLinks.=$conectfile; $argsLinks.=$confbase; $argsLinks.=$conftable; $argsLinks.=$declaration; $argsLinks.=$query; $argsLinks.=$count; $argsLinks.=$boucledebut; $argsLinks.=$namefield; $argsLinks.="echo\"<a href='Form_".$table."_update.php?row=".$var.$name0."'>".$var.$name0." ".$var.$name001."</a><br>\";".$retourligne."}".$retourligne; $argsLinks.=$brace_fin; $this->CreateFile($table."/".$table."_Links.php" , $argsLinks); for ($i=0; $i < $fields; $i++) { $type = mysql_field_type($result, $i); $name = mysql_field_name($result, $i); $len = mysql_field_len($result, $i); $flags = mysql_field_flags($result, $i); if($len >255 ){ $input_update.=" echo \"$name<textarea rows='5' cols='40' wrap='on' name='$name'>"; $input_update.=$var.$name."</textarea><br>\";\n"; } elseif($len <50 ){$input_update.="echo\"$name : <input type='text' name='$name' value='".$var.$name."'size='$len'><br>\";\n";} else{$input_update.="echo\"$name : <input type='text' name='$name' value='".$var.$name."'size='50'><br>\";\n";} } $query_update=$var."dbview->query(\"select * from ".$var."table where $name0='".$var."rowupdate'\");".$retourligne; $argsform_update=$brace_debut; $argsform_update.=$conectfile; $argsform_update.=$confbase; $argsform_update.=$conftable; $argsform_update.=$declaration; $argsform_update.=$var."rowupdate=".$var."_GET[\"row\"];"; $argsform_update.=$query_update; $argsform_update.=$count; $argsform_update.=$formaction.$rest.$fininsert; $argsform_update.=$boucledebut; $argsform_update.=$namefield; $argsform_update.=$debut_form.$input_update.$fin_form_update; $argsform_update.=$bouclefin; $this->CreateFile($table."/Form_".$table."_update.php" , $argsform_update); } } function CreateFile($fichier , $args){ $contenu = ""; $args = func_get_args(); foreach(array_slice($args, 1, count($args)) as $a) { if (is_object($a) || is_resource($a)) { } else if (is_array($a)){ $contenu .= implode("\n", array_values($a))."\n";} else {$contenu .= $a."\n"; } } if ($contenu == "") { return FALSE;} $fp = fopen($fichier, "w"); if (!$fp){ return $fp;} $r = fwrite($fp, $contenu); fclose($fp); return $r; } function creer_dossier($nom_dossier){ $exist_doss=is_dir($nom_dossier); if(!$exist_doss){mkdir ($nom_dossier, 0777); echo"<br>Dossier <b><u>".$nom_dossier." </u></b>Creer avec succes !!<br>"; } } } $class= new ClassSql(); $class->list_base(); //$class->list_table("votre_base"); //$class->list_row("votre_base","votre_table"); //$class->creer_dossier("nom_dossier"); } else{echo "<a href='install.html'>installer Tool Sql Class</a>";} ?>
j'ai vu qu'il y a vait une différence entre php4 et 5 mais ça dépasse mes cométences pour corriger
La définition des propriétés dans les class est différente entre php 4 et php 5
php 4 :
var une_prop = 'utilise le mot clé var';
php 5 :
private une_prop = 'utilise le mot clé private';
public une_prop = 'utilise le mot clé public';
Avec php 5 on choisi la porté des propriétés.
Cordialement,
.µAlexx.
Vous n'êtes pas encore membre ?
inscrivez-vous, c'est gratuit et ça prend moins d'une minute !
Les membres obtiennent plus de réponses que les utilisateurs anonymes.
Le fait d'être membre vous permet d'avoir un suivi détaillé de vos demandes et codes sources.
Le fait d'être membre vous permet d'avoir des options supplémentaires.
