Le code à mettre d'en un MODULE ,:
Source / Exemple :
'Code à mettre dans un module.
Declare Function RegQueryValueEx Lib "advapi32.dll" _
Alias "RegQueryValueExA" _
(ByVal hKey As Long, _
ByVal lpValueName As String, _
ByVal lpReserved As Long, _
lpType As Long, lpData As Any, _
lpcbData As Long) As Long
Declare Function RegOpenKeyEx Lib "advapi32.dll" _
Alias "RegOpenKeyExA" _
ByVal lpSubKey As String, _
ByVal ulOptions As Long, _
ByVal samDesired As Long, _
phkResult As Long) As Long
Declare Function RegCloseKey Lib "advapi32.dll" _
(ByVal hKey As Long) As Long
Public Const HKEY_CLASSES_ROOT = &H80000000
Public Const HKEY_CURRENT_CONFIG = &H80000005
Public Const HKEY_CURRENT_USER = &H80000001
Public Const HKEY_LOCAL_MACHINE = &H80000002
Public Const KEY_ALL_ACCESS As Long = &HF0063
Public Const ERROR_SUCCESS As Long = 0
Public Const REG_SZ As Long = 1
Function RegLireChaine(hInKey As Long, ByVal SousClef$, ByVal valname$) As String
Dim strChaine As String
Dim hSousClef As Long
Dim dwType As Long
Dim v As String
Dim SZ As Long
Dim R As Long
strChaine = ""
R = RegOpenKeyEx(hInKey, SousClef$, 0, KEY_ALL_ACCESS, hSousClef)
If R <> ERROR_SUCCESS Then GoTo Quitter
SZ = 256: v = String$(SZ, 0)
R = RegQueryValueEx(hSousClef, valname$, 0, dwType, ByVal v, SZ)
If R = ERROR_SUCCESS And dwType = REG_SZ Then
strChaine = Left$(v, SZ)
Else
strChaine = " "
End If
If hInKey = 0 Then R = RegCloseKey(hSousClef)
Quitter:
RegLireChaine = strChaine
End Function
' LE CODE A METTRE DANS VOTRE FORM
' *** Lecture de la Version de Windows ***
' Lire utilisateur enregistré
lblUtilisateur = RegLireChaine(HKEY_LOCAL_MACHINE, "SOFTWARE\Microsoft\Windows\CurrentVersion", "RegisteredOwner")
' Lire organisation enregistrée
lblOrganisation = RegLireChaine(HKEY_LOCAL_MACHINE, "SOFTWARE\Microsoft\Windows\CurrentVersion", "RegisteredOrganization")
' Lire le numéro de license
lblLicence = RegLireChaine(HKEY_LOCAL_MACHINE, "SOFTWARE\Microsoft\Windows\CurrentVersion", "ProductID")
' Lire la cle d'enregistrement
lblCle = RegLireChaine(HKEY_LOCAL_MACHINE, "SOFTWARE\Microsoft\Windows\CurrentVersion", "ProductKey")
' Lire le nom du programme
lblNom = RegLireChaine(HKEY_LOCAL_MACHINE, "SOFTWARE\Microsoft\Windows\CurrentVersion", "ProductName")
' Lire la Version
lblVersion = RegLireChaine(HKEY_LOCAL_MACHINE, "SOFTWARE\Microsoft\Windows\CurrentVersion", "VersionNumber")
' *** Lecture du materiel ***
' Lire le type d'ordinateur
lblProcesseur = RegLireChaine(HKEY_LOCAL_MACHINE, "Hardware\Description\System\CentralProcessor\0", "Identifier")
' Lire le MMX Identificateur
lblMMX = RegLireChaine(HKEY_LOCAL_MACHINE, "Hardware\Description\System\CentralProcessor\0", "MMXIdentifier")
' Lire le Vendor Identification
lblVendor = RegLireChaine(HKEY_LOCAL_MACHINE, "Hardware\Description\System\CentralProcessor\0", "VendorIdentifier")
Conclusion :
Aucune configuration de formulaire ici, les Label "lblxxxxxx" représente les noms de labels que vous désirez obtenir. Dans cet exemple, vous avez l'exemple qui vous montre comment lire dans la base de registre, avec quelques clés utililes qui vous donnerons différentes informations sur l'utilisateur ou sur la machine.
Pour avoir un bon exemple, téléchargez le fichier Zip en bas de cette page qui vous en montrera un peu plus.
'Excuse, voila le ZIP
Vous n'êtes pas encore membre ?
inscrivez-vous, c'est gratuit et ça prend moins d'une minute !
Les membres obtiennent plus de réponses que les utilisateurs anonymes.
Le fait d'être membre vous permet d'avoir un suivi détaillé de vos demandes et codes sources.
Le fait d'être membre vous permet d'avoir des options supplémentaires.
