ce programme utilise des web services et les code PHP et une data base sur mon site pour connecter. tres rapide , et aussi j'ai ajouter a chaque contact un inbox pour les message et aussi liste des contact et search pour les contact et plien des truc .........
Source / Exemple :
//code de la WebService fait par PHP
//.....................................................START
<?php
// server folder : http://egypto.awardspace.com/server/connect.php
// Copyright © EGPTO.NET 2006. All rights reserved.
//By : Peter Gad Shehata
//email: Peter_Gad1@yahoo.com
//Phone: 0202-0125669727
$client_message = trim($client_message);
$client_info ;
//$ip = getenv ("REMOTE_ADDR");
connect_to_database () ;
//$client_message = "login";
//$client_info = "id:half_angelpw:0123883491" ;
//echo $client_info."<br>" ;
switch ($client_message) {
//--------------------------------------------------------------------------------case1
//hi
case 'hi' :
echo 'ip:' . $ip ;
Break;
//--------------------------------------------------------------------------------case2
case "login" :
$userid = trim(substr ($client_info,3,strpos($client_info , "pw")-3));
$userpass = substr ($client_info,strpos($client_info , "pw") +3 , strlen($client_info)-1);
//--------------------------------------------------------------------------------case3
$result = mysql_query ( "select userid_ , userpass_, username_ from users_login where userid_ = '$userid' ");
$row = mysql_fetch_array($result);
if ($userid == $row[0] and $userpass == $row[1]){
$result = getall_Dlogin ($userid) ;
echo "lit"."*/w".$row[2].$result ;
exit ;
}else{
echo 'lif';
exit ;
Break;
//---------------------------------------------------------------------------------case1
case "send new message":
$from = trim(substr ($client_info,strpos($client_info , "frm:")+4,strpos($client_info , "to:")-4));
$to = trim(substr ($client_info,strpos($client_info , "to:")+3,strpos($client_info , "sub:")-strpos($client_info , "to:")-3));
$subject = trim(substr ($client_info,strpos($client_info , "sub:")+4,strpos($client_info , "msg:")-strpos($client_info , "sub:")-4));
$message = trim(substr ($client_info,strpos($client_info , "msg:")+4,strpos($client_info , "date:")-strpos($client_info , "msg:")-4));
$date = trim(substr ($client_info,strpos($client_info , "date:")+5,strlen($client_info)-1));
send_message ($from,$to,$date,$subject,$message);
Break;
//----------------------------------------------------------------------------------cas5
case "show all new messages":
$result = dir_myinbox ($client_info,"all new messages");
echo "nmg".$result ;
exit ;
Break;
//---------------------------------------------------------------------------------- case6
case "delete message":
$m_from = trim(substr ($client_info,strpos($client_info , "frm:")+4,strpos($client_info , "date:")-4));
$m_date = trim(substr ($client_info,strpos($client_info , "date:")+5,strpos($client_info , "tab:")-strpos($client_info , "date:")-5));
$m_table = trim(substr ($client_info,strpos($client_info , "tab:")+4,strlen($client_info)-1));
$table = $m_table . '_inbox';
mysql_query ( "delete from $table where from_ = '$m_from' and date_ = '$m_date'");
echo 'mgd';
exit ;
Break;
//---------------------------------------------------------------------------------- case7
case "show all message":
dir_myinbox ($client_info,"all messages");
Break;
//---------------------------------------------------------------------------------- case8
case "show all contacts":
$c_table = $client_info ;
getallcontacts_from_my_list($c_table);
Break;
//---------------------------------------------------------------------------------- case9
case "add a contact":
$contact = substr ($client_info ,0,strpos($client_info , "/u*")) ;
$username = substr ($client_info ,strpos($client_info , "/u*")+3,strpos($client_info , "/e*")-strpos($client_info , "/u*")-3);
$result = add_a_contact($contact,$username);
if ($result == "0") {
echo 'car';
exit ;
}elseif ($result == "1"){
echo 'cad';
exit ;
}else{
echo 'cau';
} exit ;
Break;
//---------------------------------------------------------------------------------- case10
case "remove a contact":
$result = remove_a_contact($contact,$username);
if ($result == 1){
echo 'rct';
exit ;
}else{
echo 'rcf';
} exit ;
Break;
//---------------------------------------------------------------------------------- case11
case "un/block a contact":
$result = block_unblock_a_contact($contact,$username);
if ($result == 1){
//block true
echo 'bct';
exit ;
}elseif ($result == 2){
//unblock true
echo 'ubc';
exit ;
}else{
echo 'bcf';
exit ;
Break;
//---------------------------------------------------------------------------------- case12
case "read message":
Mysql_query("update $table set read_ = '0' where from_ = '$m_from' and date_ ='$m_date'");
echo 'mgr';
exit ;
Break;
//---------------------------------------------------------------------------------- case13
case "change my status":
$nickname = substr ($client_info ,0,strpos($client_info , "/s*")) ;
$status = substr ($client_info ,strpos($client_info , "/s*")+3,strpos($client_info , "/e*")-strpos($client_info , "/s*")-3);
change_status($nickname,$status);
echo 'usg';
exit ;
Break;
//---------------------------------------------------------------------------------- case14
case "get contact profile":
$contact = $client_info ;
$profile = get_contact_profile($contact);
echo 'cpl'.$profile;
exit ;
Break;
//---------------------------------------------------------------------------------- case15
case "search people":
$sstatus = substr($client_info ,strpos($client_info , "*/s")+3,strpos($client_info , "*/k")-strpos($client_info , "*/s")-3);
$skeyword = substr($client_info ,strpos($client_info , "*/k")+3,strpos($client_info , "*/a")-strpos($client_info , "*/k")-3) ;
$sageh = substr($client_info ,strpos($client_info , "*/a")+3,strpos($client_info , "*/l")-strpos($client_info , "*/a")-3) ;
$slocation = substr($client_info ,strpos($client_info , "*/l")+3,strpos($client_info , "*/g")-strpos($client_info , "*/l")-3) ;
$sgender = substr($client_info ,strpos($client_info , "*/g")+3,strpos($client_info , "*/e")-strpos($client_info , "*/g")-3) ;
switch ($sageh) {
case "17":
$sagel = "0" ;
Break;
//--------------------case2
case "29":
$sagel = "18" ;
Break;
case "44":
$sagel = "30" ;
Break;
case "60":
$sagel = "45" ;
Break;
case "61":
$sagel = "60" ;
Break;
$sage = array ($sagel,$sageh);
people_search ($sstatus,$skeyword,$sage,$slocation,$sgender) ;
Break;
//---------------------------------------------------------------------------------- case16
case "get last status":
$user = $client_info ;
$status = check_user_status ($user) ;
echo 'uls'. $status ;
exit ;
Break;
//---------------------------------------------------------------------------------- case17
case "chat_message":
$username =substr($client_info ,strpos($client_info , "*/u")+3,strpos($client_info , "*/c")-strpos($client_info , "*/u")-3);
$contact =substr($client_info ,strpos($client_info , "*/c")+3,strpos($client_info , "*/m")-strpos($client_info , "*/c")-3);
$message =substr($client_info ,strpos($client_info , "*/m")+3,strpos($client_info , "*/s")-strpos($client_info , "*/m")-3);
//$fstyle = substr($client_info ,strpos($client_info , "*/s")+3,strpos($client_info , "*/o")-strpos($client_info , "*/s")-3);
// $fcolor substr($client_info ,strpos($client_info , "*/o")+3,strpos($client_info , "*/z")-strpos($client_info , "*/o")-3);
// $fsize substr($client_info ,strpos($client_info , "*/z")+3,strpos($client_info , "*/e")-strpos($client_info , "*/z")-3);
$font = substr($client_info ,strpos($client_info , "*/s"),strpos($client_info , "*/e")-strpos($client_info , "*/s"));
send_instant_message($contact,$message,$font,$username);
echo 'ims';
exit ;
Break;
//---------------------------------------------------------------------------------- case18
case "readchat_message":
$username = $client_info ;
read_chatmessage ($username);
Break;
case "get_myalldata":
getall_Nfunction ($username) ;
Break;
Default;
echo 'not understand this request';
exit ;
function send_message ( $from,$to,$date,$subject,$message) {
$result = mysql_query ( "select userid_ from users_login where userid_ = '$to' ");
if ($row[0] == $to ) {
$table = $to . '_inbox' ;
mysql_query("Insert into $table ( from_ , date_ , subject_ , message_ , read_ ) Values ( '$from','$date','$subject','$message','1')");
echo 'message has been sent to: ' .$to;
exit ;
}else{
echo $to. ' not found ';
exit ;
}//--------------------------------end if
//----------------------------------------------------------------end function
function dir_myinbox ($user_table,$inbox_data){
$table = $user_table . '_inbox' ;
switch ($inbox_data) {
//-----------------------------case1
case "all new messages":
$result = Mysql_query("select * from $table where read_ = '1' ");
$Nmsg = mysql_num_rows($result) ;
if ($Nmsg == 0 ) {
return '0' ;
}else{
$result = get_allnew_messages ($user_table , $Nmsg,"all new messages");
return $result ;
Break;
//------------------------------case2
case "all messages":
$result = Mysql_query("select * from $table where read_ = '0' OR '1' ");
get_allnew_messages ($user_table , $Nmsg,"all messages");
Break;
//------------------------------case3
case "all new messages count":
return $Nmsg ;
Break;
//-----------------------------------------------------------------end function
function get_allnew_messages ($table_name , $data_count , $data ){
$table = $table_name . '_inbox';
switch ($data){
$result = mysql_query ( "select from_ , date_ , subject_ , message_ ,read_ from $table where read_ = '1' ");
Break;
//-----------------------------case2
$result = mysql_query ( "select from_ , date_ , subject_ , message_ ,read_ from $table where read_ = '0' OR '1' ");
Break;
while ($row = mysql_fetch_array($result)) {
$all_data = $all_data."*/\f*".$row[0]."*/\d*".$row[1]."*/\s*".$row[2]."*/\m*".$row[3]."*/\a*".$row[4]."*/\e*"."*/\line" ;
} //end while
switch ($data){
return $data_count .$all_data ;
Break;
echo 'amg'.$data_count .$all_data;
exit ;
Break;
function getallcontacts_from_my_list ($table){
addmy_timelogin ($table);
$table1 = $table . '_contact' ;
$result = Mysql_query("select * from $table1 ");
while ($row = mysql_fetch_array($result)){
//$row[0]
$block_me = $row[2];
if ($block_me == 1){
$status = "offline";
}else{
$status = check_user_status ($row[0]);
$all_data = $all_data . "*/n". $row[0] ."*/b". $row[1]."*/s".$status."*/e"."*/line" ;
} //end while
$nmsgcount = dir_myinbox ($table,"all new messages count");
return $Nmsg. $all_data ;
} //-----------------------------------------------------------------end function
function check_user_status ($nickname){
$result = Mysql_query("select time_login ,status from users_status where nickname = '$nickname' ");
$time_login = array ( substr($row[0],0,2), substr($row[0],2,2), substr($row[0],4,2),substr($row[0],6,2),substr($row[0],8,2),substr($row[0],10,4));
//mktime($hour1,$minutes1,$seconds1,$month1,$day1,$year1)
$time_login = mktime($time_login[0],$time_login[1],$time_login[2],$time_login[3],$time_login[4],$time_login[5]) ;
$time_now = mktime(date("H"),date("i"),date("s"),date("m"),date("d"),date("Y")) ;
$differece = ($time_now - $time_login );
//10 seconds
if ($differece < 10) {
$status = $row[1];
}else{
$status ="offline";
return $status ;
function add_a_contact($contact,$username) {
$result = Mysql_query("select * from users_status where nickname = '$contact' ");
$N = mysql_num_rows($result) ;
if ($N == 1){
$table1 = $username . '_contact' ;
$result = Mysql_query("select * from $table1 where contacts = '$contact' ");
$Nc = mysql_num_rows($result) ;
if ($Nc == 1 ){
return "2" ;
}else{
mysql_query("Insert into $table1 ( contacts,block ) Values ( '$contact','0')");
$table1 = $contact . '_contact' ;
$result = Mysql_query("select * from $table1 where contacts = '$username' ");
if ($Nc <> 1){
mysql_query("Insert into $table1 ( contacts,block ) Values ( '$username','2')");
return "1"; }
}else{
return "0";
function remove_a_contact ($contact,$username){
if ($N == 1){
Mysql_query("delete from $table1 where contacts = '$contact'");
return "1" ;
}else{
return "0" ;
function block_unblock_a_contact ($contact,$username){
$result = Mysql_query("select block , block_me from $table1 where contacts = '$contact' ");
if ($N == 1){
if ($row[0] == 0){
Mysql_query("update $table1 set block = '1' where contacts = '$contact'");
Mysql_query("update $table1 set block_me = '1' where contacts = '$username'");
return "1" ;
}else{
Mysql_query("update $table1 set block = '0' where contacts = '$contact'");
Mysql_query("update $table1 set block_me = '0' where contacts = '$username'");
return "2" ;
}else{
return "3" ;
function addmy_timelogin ($user_rows){
$timelogin = date("HismdY");
Mysql_query("update users_status set time_login = '$timelogin' where nickname = '$user_rows'");
}//-----------------------------------------------------------------end function
function change_status ($nickname , $status){
Mysql_query("update users_status set status = '$status' where nickname = '$nickname'");
function get_contact_profile ($contact){
$result = mysql_query ( "select username_ , userage_ , userlocation_ , usergender_ , usermail_ from users_login where userid_ = '$contact' ");
$profile = "*/n".$row[0]."*/a".$row[1]."*/l".$row[2]."*/g".$row[3]."*/i".$row[4]."*/e" ;
return $profile ;
function people_search ($sstatus,$keyword,$age,$location,$gender){
if ($keyword == ""){
if ($sage[0] == "60"){
//age over 60
$result = mysql_query ( "select userid_ , userage_ , userlocation_ , usergender_ from users_login where userlocation_ ='$location' and usergender_ = '$gender' and userage_ > $age[0] ");
}else{
$result = mysql_query ( "select userid_ , userage_ , userlocation_ , usergender_ from users_login where userlocation_ ='$location' and usergender_ = '$gender' and userage_ between $age[0] and $age[1] ");
}else{
//age over 60
$result = mysql_query ( "select userid_ , userage_ , userlocation_ , usergender_ from users_login where userid_ like '%$keyword%' and userlocation_ ='$location' and usergender_ = '$gender' and userage_ > $age[0] ");
}else{
$result = mysql_query ( "select userid_ , userage_ , userlocation_ , usergender_ from users_login where userid_ like '%$keyword%' and userlocation_ ='$location' and usergender_ = '$gender' and userage_ between $age[0] and $age[1] ");
if ($Nmsg == 0){
echo 'cse'.$Nmsg ;
exit ;
if ($sstatus == "1" ){
$cstatus = check_user_status ($row[0]);
if ($cstatus == "online" or $cstatus == "away" or $cstatus == "busy"){
$all_data = $all_data . "*/n". $row[0] ."*/a". $row[1] ."*/l". $row[2] ."*/g". $row[3] ."*/e" . "*/line" ;
}else{
$Nmsg = $Nmsg - 1 ;
}else{
} //end while
echo 'cse'.$Nmsg. $all_data ;
exit ;
function send_instant_message($contact,$message,$font,$username){
$serverdate = date("H:i:s m/d/Y");
$table1 = $contact . '_chat' ;
mysql_query("Insert into $table1 ( contact_ , date_ , message_ , font_ ) Values ( '$username','$serverdate','$message','$font')");
function read_chatmessage ($username){
$table1 = $username . '_chat' ;
$result = Mysql_query("select contact_ , date_ , message_ , font_ from $table1 ");
if ($N > 0){
// Start
Mysql_query("delete from $table1 where contact_ = '$row[0]' and message_ = '$row[2]'");
// */c contact */d date */m message */s font style */o font color */z font size */e */line
$all_data = $all_data . "*/a". $row[0] ."*/d". $row[1] ."*/m". $row[2] . $row[3] ."*/e" . "*/line" ;
} //end while
return $N.$all_data ;
}else{
return '0';
function connect_to_database (){
$db = mysql_connect ( "localhost","root","") ;
mysql_select_db("safary_messenger",$db);
function getall_Nfunction ($username){
//---username
addmy_timelogin ($username) ;
//---username
$nmsgcount = dir_myinbox ($username,"all new messages count");
$mycontactlist = getallcontacts_from_my_list ($username);
$mychatmsg = read_chatmessage ($username) ;
$data = '*/g' . $nmsgcount . "*/c" . $mycontactlist . '*/data2' . $mychatmsg ;
echo 'ald'.$data ;
exit ; //------------------------------------------------------------end function
function getall_Dlogin ($username){
//---username
$mynewmsgdata = dir_myinbox ($username,"all new messages") ;
$mylaststatus = check_user_status ($username) ;
return '*/u' . $mylaststatus . "*/c" . $mycontactlist . '*/data2' . $mynewmsgdata ;
mysql_close($db );
Conclusion :
vous pouvez trouver aussi le source code sur cette link
http://egypto.awardspace.com/services/uploadfiles/files/Messenger.rar
Vous n'êtes pas encore membre ?
inscrivez-vous, c'est gratuit et ça prend moins d'une minute !
Les membres obtiennent plus de réponses que les utilisateurs anonymes.
Le fait d'être membre vous permet d'avoir un suivi détaillé de vos demandes et codes sources.
Le fait d'être membre vous permet d'avoir des options supplémentaires.
