Traduction du "length-disassembler engine, 32-bit" de zombie
Contenu du snippet
Utilisé la fonction GetInstrLen pour connaitre la talle de instruction ASM situé a une adresse précise. Ce n'est qu'un encapsulage de la fonction ASM de ZOMBIE dans une unité Delphi
Source / Exemple :
unit LDE32;
// Original Coder :
// LDE32, Length-Disassembler Engine, 32-bit, (x) 1999-2000 Z0MBiE
// special edition for REVERT tool
// version 1.05
// Delphi Convertion - DevNull - 2004
interface
Uses types;
const
table_1: array[$00..$FF] of DWord =
($4000, $4000, $4000, $4000, $8000, $8000,     0,     0,
 $4000, $4000, $4000, $4000, $8000, $8000, $0008,     0,
     0,     0,     0,     0,     0,     0,     0,     0,
     0,     0, $4000, $4000, $0008, $0008, $1008, $1008,
 $2000, $6000, $0100, $4100,     0,     0,     0,     0,
 $0100, $0100, $0100, $0100, $0100, $0100, $0100, $0100,
 $4100, $6000, $4100, $4100, $4000, $4000, $4000, $4000,
 $4000, $4000, $4000, $4000, $4000, $4000, $4000, $4000,
     0,     0, $2002,     0,     0,     0,     0,     0,
 $0020, $0020, $0020, $0020,     0,     0,     0,     0,
 $0100, $2000,     0,     0,     0,     0,     0,     0,
 $2000, $2000, $2000, $2000, $2000, $2000, $2000, $2000,
 $4100, $4100, $0200,     0, $4000, $4000, $4100, $6000,
 $0300,     0, $0200,     0,     0,     0,     0,     0,
 $4000, $4000, $4000, $4000, $0100, $0100,     0,     0,
 $2000, $2000, $2002, $0100,     0,     0,     0,     0,
 $0008,     0, $0008, $0008,     0,     0,     0,     0,
     0,     0,     0,     0,     0,     0, $4000, $4000);
table_0F: array[$00..$FF] of Integer =
($4000, $4000, $4000, $4000,    -1,    -1,     0,    -1,
     0,     0,     0,     0,    -1,    -1,    -1,    -1,
    -1,    -1,    -1,    -1,    -1,    -1,    -1,    -1,
     0,     0,     0, $4000, $4100, $4000,    -1,    -1,
     0,     0,     0, $4000, $4100, $4000,    -1, $4000,
    -1,    -1, $4100, $4000, $4000, $4000, $4000, $4000,
 $4000, $4000,    -1,    -1,    -1,    -1,    -1,    -1,
    -1,    -1,    -1,    -1,    -1,    -1,    -1,    -1) ;
Function GetInstrLen(Pos : Pointer): byte;
implementation
Var
pOpCode: pointer;
asm
                mov     pOpCode, Pos
                mov     ecx, Pos    // ECX = opcode ptr
                xor     edx, edx    // EDX = 0
                xor     eax, eax    // EAX = 0
@@Prefix:
                and     dl , not $0008
                mov     al, [ecx]
                inc     ecx
                or      edx, DWord(table_1[eax*4])
                test    dl, $0008
                jnz     @@Prefix
                cmp     al, 0F6h
                je      @@test
                cmp     al, 0F7h
                je      @@test
                cmp     al, 0CDh
                je      @@int
                cmp     al, 0Fh
                je      @@0F
@@cont:
                test    dh, $8000 shr 8
                jnz     @@dataw0
@@dataw0done:
                test    dh, $4000 shr 8
                jnz     @@modrm
@@exitmodrm:
                test    dl, $0020
                jnz     @@mem67
@@mem67done:
                test    dh, $2000 shr 8
                jnz     @@data66
@@data66done:
                mov     eax, ecx
                sub     eax, pOpCode
                and     edx,$0001+$0002+$0004+$0100+$0200+$0400
                add     al, dl
                add     al, dh
@@exit:         pop     ecx
                pop     ebp
                ret
@@test:         or      dh, $4000 shr 8
                test    byte ptr [ecx], 00111000b  // F6/F7 -- test
                jnz     @@cont
                or      dh, $8000 shr 8
                jmp     @@cont
@@int:          or      dh, $0100 shr 8
                cmp     byte ptr [ecx], 20h
                jne     @@cont
                or      dh, $0400 shr 8
                jmp     @@cont
@@0F:           mov     al, [ecx]
                inc     ecx
                or      edx, DWord(table_0F[eax*4])
                cmp     edx, -1
                jne     @@cont
@@error:        mov     eax, edx
                jmp     @@exit
@@dataw0:       xor     dh, $2000 shr 8
                test    al, 00000001b
                jnz     @@dataw0done
                xor     dh, ($2000+$0100) shr 8
                jmp     @@dataw0done
@@mem67:        xor     dl, $0002
                test    dl, $0010
                jnz     @@mem67done
                xor     dl, $0004+$0002
                jmp     @@mem67done
@@data66:       xor     dh, $0200 shr 8
                test    dh, $1000 shr 8
                jnz     @@data66done
                xor     dh, ($0400+$0200) shr 8
                jmp     @@data66done
@@modrm:        mov     al, [ecx]
                inc     ecx
                mov     ah, al  // ah=mod, al=rm
                and     ax, 0C007h
                cmp     ah, 0C0h
                je      @@exitmodrm
                test    dl, $0010
                jnz     @@modrm16
@@modrm32:      cmp     al, 04h
                jne     @@a
                mov     al, [ecx]       // sib
                inc     ecx
                and     al, 07h
@@a:            cmp     ah, 40h
                je      @@mem1
                cmp     ah, 80h
                je      @@mem4
                cmp     ax, 0005h
                jne     @@exitmodrm
@@mem4:         or      dl, $0004
                jmp     @@exitmodrm
@@mem1:         or      dl, $0001
                jmp     @@exitmodrm
@@modrm16:      cmp     ax, 0006h
                je      @@mem2
                cmp     ah, 40h
                je      @@mem1
                cmp     ah, 80h
                jne     @@exitmodrm
@@mem2:         or      dl, $0002
                jmp     @@exitmodrm
end;
end.
Vous n'êtes pas encore membre ?
inscrivez-vous, c'est gratuit et ça prend moins d'une minute !
Les membres obtiennent plus de réponses que les utilisateurs anonymes.
Le fait d'être membre vous permet d'avoir un suivi détaillé de vos demandes et codes sources.
Le fait d'être membre vous permet d'avoir des options supplémentaires.
Du même auteur (/dev/null)
